Vedänkin takaisin!
Yllä oleva on siis tuo 80x35x21 eikä 80x35x17 jatkan etsintää...
National 307L
T85
T85D
T10P
T10V
NATIONAL Part # 1207L Ball Bearing; Bore=1.378", Outer Diameter=2.8346", Width=0.6693"
Borg-Warner T96F; 3 Speed (Only 1 Remaining)
NATIONAL Part # 306LO Ball Bearing; Bore=1.1811", Outer Diameter=2.8346", Width=0.748"
Borg-Warner T96J; 3 Speed
NATIONAL Part # 308L1 Ball Bearing; Bore=1.5748", Outer Diameter=3.5433", Width=0.7874"
Borg-Warner T15; 3 Speed
Nyt löytyi tällainen:
Manual : Main Shaft Bearing
SKF Part # 6307NRJ {Click Info Link for Alternate/OEM Part Numbers} Inside diameter=1.3780"; Outside diameter=3.1496"; Width=.826IN
3 speed trans.; T85D Trans.; Front (Only 2 Remaining)Inside diameter=1.3780"; Outside diameter=3.1496"; Width=.826IN
Alternate/OEM Part Number(s): 02557, 11109, 12334471, 12338627, 12339882, 12350292, 150618, 1541089, 196519, 196614C, 207372, 2124517, 23311073, 23311074, 23311075, 26H7025, 28995880, 3150654, 3192371, 3410048, 458512, 4637774, 540812, 562837, 563906, 574863, 7703307, 8941787340, 899588, 8D7065, 8L7025, 8L7065, 9036330014, 903633500977, 904600, 907247, 907271, 907372, 907913, 908182, 9197001, 927630, 94178734, 9419379, 9419397, 954127, 954869, 954953, 954985, 996064307, B6C7065A, C2DZ7025A, D2110037, D67Z7025A, E1ZZ7065A, E69Z7025A, J3150654, J3192371, MD701728, T7703307, XAA9588
AMERICAN MOTORS (1958 - 1966)
BUICK (1962 - 1965)
CHECKER (1961 - 1970)
CHEVROLET (1953 - 1991)
CHRYSLER (1960 - 1967)
DODGE (1957 - 2005)
EDSEL 1958
FORD (1948 - 1997)
GMC (1961 - 1991)
INTERNATIONAL (1956 - 1975)
MAZDA (1970 - 1988)
MERCURY (1955 - 1983)
MITSUBISHI (1983 - 1996)
NISSAN (1986 - 1997)
OLDSMOBILE (1962 - 1963)
PLYMOUTH (1976 - 1983)
PONTIAC (1960 - 1974)
STUDEBAKER (1956 - 1964)
TOYOTA (1989 - 1995)
