Jarrupääsylkkä -62 Classicciin
dart-66
Viesti Kirjoittaja dart-66 »
Bendixin tekele, kupeessa 617386 ja 2631, avun ulottumattomissa. Vinkkejä...
https://www.youtube.com/watch?v=PGO0aWJkrmo150s">https://www.youtube.com/watch?v=PGO0aWJkrmo
Tuolta tilaisin korjaus-sarjan
dart-66
Kun on syöpynyt...
Tuossa vinkki tietäjä Farnalta, jos ei löydy oikeaa...
"It's a Wagner master cylinder and hard to get. Americans used the same one. You can adapt a later model Rambler master cylinder. I put a mid 60s MC on my 61, I think it was a 70 Hornet MC. You'll have to replace the hard lines from the junction block to the MC, and may need one or two adapters, but it works just fine. I don't recall filing the holes in the MC to fit, but it's possible that the studs on the firewall are a little closer or further apart. If they are it's only a small amount, nothing a file wouldn't fix. Bore and stroke of the MC are the important issues, and they are the same. "
https://www.ramblerparts.com/catalog.php
https://www.blaserauto.com/
Tuossa muutama paikka
dart-66
Kiitos  :)
Tuo sylkän vaihto uudempaan oli jo tiedossa mutta ei ainakaan vielä ole edes toissijainen vaihtoehto.
Muut linkit lähtivät tarvitsijalle.
