tuata tuata. naputtelin tossa toiselle foorumille tarinaa tämän kevään harjoittelusta mopon kanssa.. kopsaan suoraan tähän lontooksi... jos kiinnostaa niin tutustukaas
![Silmänisku Silmänisku](https://amccf.com/YaBB_2.6.0/public_html/yabbfiles/Templates/Forum/default/wink.gif)
"tein ite ja säästin..."
![Kliseinen Kliseinen](https://amccf.com/YaBB_2.6.0/public_html/yabbfiles/Templates/Forum/default/cheesy.gif)
And back yet again!
![Hymiö Hymiö](https://amccf.com/YaBB_2.6.0/public_html/yabbfiles/Templates/Forum/default/smiley.gif)
Been quite busy with my cars and the house so the bike has been put on the background a bit in the last half a year or so. However I started on the seat and it's going along 'OK' for my first try at making one from scratch.
![seat_01_seatpan.jpg seat_01_seatpan.jpg](http://fi.ath.cx/fi/cb750kz/seat_01_seatpan.jpg)
So here's what I started with, some sheetmetal, bent straight on the sides and a few hammers. Did not copy the original seat pan as I first thought, because it would have ended up looking too much like the original which I am intent on replacing with something that looks better to my eyes.
![seat_02_seatpan-test.jpg seat_02_seatpan-test.jpg](http://fi.ath.cx/fi/cb750kz/seat_02_seatpan-test.jpg)
After some cutting and again hammering, it slowly dawned on my how much work is ahead, oh well.. I did get started...
![seat_03_seatpan-test.jpg seat_03_seatpan-test.jpg](http://fi.ath.cx/fi/cb750kz/seat_03_seatpan-test.jpg)
![seat_04_seatpan-metal.jpg seat_04_seatpan-metal.jpg](http://fi.ath.cx/fi/cb750kz/seat_04_seatpan-metal.jpg)
![seat_05_seatpan-metal.jpg seat_05_seatpan-metal.jpg](http://fi.ath.cx/fi/cb750kz/seat_05_seatpan-metal.jpg)
I started with getting the general lines of the seat, and then measured how much I'd need to modify it to make it fit from the sides as well...
![seat_06_seatpan-test.jpg seat_06_seatpan-test.jpg](http://fi.ath.cx/fi/cb750kz/seat_06_seatpan-test.jpg)
First 'test-seatings completed', realized it was much too wide, especially in the front so I thought to continue with that...
![seat_07_cutting.jpg seat_07_cutting.jpg](http://fi.ath.cx/fi/cb750kz/seat_07_cutting.jpg)
Tried to minimize the cutting, but...
![seat_08_more-cutting.jpg seat_08_more-cutting.jpg](http://fi.ath.cx/fi/cb750kz/seat_08_more-cutting.jpg)
![seat_11_seatpan-mockup.jpg seat_11_seatpan-mockup.jpg](http://fi.ath.cx/fi/cb750kz/seat_11_seatpan-mockup.jpg)
Ended up cutting the pan into four pieces, it just would not fit right otherwise. But it was getting close to what I wanted, slowly but surely...
![seat_09_seatpan-mockup.jpg seat_09_seatpan-mockup.jpg](http://fi.ath.cx/fi/cb750kz/seat_09_seatpan-mockup.jpg)
![seat_10_seatpan-mockup.jpg seat_10_seatpan-mockup.jpg](http://fi.ath.cx/fi/cb750kz/seat_10_seatpan-mockup.jpg)
After playing around with a 4-piece puzzle, I roughly taped the parts in the right place.
![seat_12_seatpan-tacked.jpg seat_12_seatpan-tacked.jpg](http://fi.ath.cx/fi/cb750kz/seat_12_seatpan-tacked.jpg)
Since I'm no welder, I took a short trip to my mates house and he tacked the 4 pieces together. Well enough so they stick, but stay adjustable. At this time I also realized I'd have to fasten the seat somehow to the frame, so I ended up using the back fender support for the holes which I can bolt thru and from front I kept it simple, just a small piece of 4mm steel which slides under the tank. I did think about using the original seat fastening system where it would stay openable, but no such luck - they were simply too wide for what I was designing - so I had to cut the original seat fasteners off. Pity, but they're intact if I want to revert back to the BIG seat.
![seat_14_seatpan-welded.jpg seat_14_seatpan-welded.jpg](http://fi.ath.cx/fi/cb750kz/seat_14_seatpan-welded.jpg)
And again to my mates house for some welding, this time full on welds not tacking. Also the bolts to the rear, due to the fact that I couldn't reach them after the padding is on. So I will have to remove the rear fender to take off the seat in the future. A price i'll gladly pay.
![seat_13_seatpan-grinded.jpg seat_13_seatpan-grinded.jpg](http://fi.ath.cx/fi/cb750kz/seat_13_seatpan-grinded.jpg)
![seat_15_seatpan-mockup.jpg seat_15_seatpan-mockup.jpg](http://fi.ath.cx/fi/cb750kz/seat_15_seatpan-mockup.jpg)
![seat_16_seatpan-cleaned.jpg seat_16_seatpan-cleaned.jpg](http://fi.ath.cx/fi/cb750kz/seat_16_seatpan-cleaned.jpg)
And after getting a result I was happy with I just grinded the welds, did some test-seating (and you should have seen me smile..
) and cleaned up the pan of surface rust from storage + applied some black industrial strength paint on it.
So now I had something to sit on, but hmm. Never done any work on padding or leather so... I looked around what I could find in the storage and camping mattress hit my eye. That just might work...
![seat_17_padding-glue.jpg seat_17_padding-glue.jpg](http://fi.ath.cx/fi/cb750kz/seat_17_padding-glue.jpg)
After applying spray glue to the seatpan...
![seat_18_padding-camping.jpg seat_18_padding-camping.jpg](http://fi.ath.cx/fi/cb750kz/seat_18_padding-camping.jpg)
And cutting the camping mattress into a bit more manageable size and also spray glue on that and off to wait 15 minutes for them to cure.
![seat_19_padding-pushed.jpg seat_19_padding-pushed.jpg](http://fi.ath.cx/fi/cb750kz/seat_19_padding-pushed.jpg)
![seat_20_padding-pushed.jpg seat_20_padding-pushed.jpg](http://fi.ath.cx/fi/cb750kz/seat_20_padding-pushed.jpg)
I was suprised how well the camping mattress adjusted to the contours of the seat pan, just enough pressure without ripping it and hold a few seconds and the glue did it's job. I did have to cut a few direct corners and also decided to leave some extra in the front bottom to insulate any possible rattling of metal to metal.
![seat_21_padding-molded.jpg seat_21_padding-molded.jpg](http://fi.ath.cx/fi/cb750kz/seat_21_padding-molded.jpg)
![seat_22_padding-molded.jpg seat_22_padding-molded.jpg](http://fi.ath.cx/fi/cb750kz/seat_22_padding-molded.jpg)
And then the underside... slowly but surely bending it and pushing it to the glue on the backsides. Unbelievable how well it took on.
![seat_23_padding-mockup.jpg seat_23_padding-mockup.jpg](http://fi.ath.cx/fi/cb750kz/seat_23_padding-mockup.jpg)
And after letting it dry for about 2 hours I tested it and realized one mattress was too little so I put on another on top. still trying to decide if I should and a third layer, we'll see....
Next I'm hoping to hit some fabric store and score some fake or real leather to cover it up, same idea basicly, glue and putting it on...
In the last pic you can also see I finally found the mirrors I wanted (and some el cheapo handles I've always had on my bikes) and the rear light jumped to my sight in a local motorcycle store, seems to be close enough to what I wanted so I'll just go with it.
![mirrors_handlebars.jpg mirrors_handlebars.jpg](http://fi.ath.cx/fi/cb750kz/mirrors_handlebars.jpg)
![taillight_mockup.jpg taillight_mockup.jpg](http://fi.ath.cx/fi/cb750kz/taillight_mockup.jpg)
Still mockup phase, we'll see if I end up putting it a bit higher up... Also the rear fender placement is getting close, we'll see more on that next week.
What I'm currently doing are the carbs, based on the mcgregor cleaning manual. Damn that is a good piece of work, never worked on this type of carbs, but it seems to be going well. Second soaking ongoing (first I soaked all parts, cleaned them up and now it's the carb bodies until tomorrow..). I'll post some more maybe tomorrow on them.
Hoping to get the bike on the road for next weekend to a BBQ at a mates place...
